MJC6125
- Apr 9, 2017
- 120
I have had many projects where it makes sense to balloon frame wood stud walls because the roof requires a tall parapet or the parapet is acting as a guardrail for a rooftop patio. See the attached pdf for an example wall section. I'm wondering how people deal with the anchorage of the stud wall to the diaphragm without inducing cross grain bending in the ledger? Here is a list of a few ideas I've had or used in the past. Does anybody have any recommendations on what works best (especially based on constructability)?
A. Don't worry about the cross-grain bending. I don't know how you can do this since there is no design value for cross grain bending, but I'm sure this has been done in the past and has worked fine.
B. Use a Simpson strap anchor that runs along the length of the joists and then gets wrapped around the stud. I've used this method in the past with Simpson twist straps (LTS/MTS/HTS), and put one every 4'-0". The issue is the studs need to line up properly with the joists every 4'-0" and I don't know how easy it would be to install. This is a similar solution to the joist anchors that are used with CMU walls anchored to wood diaphragms (specifically in high seismic areas).
C. One thought I had was using an OSB rim board product as the ledger. I have never done this, and I think all the commercially available OSB rim boards are too thin to get the joist hanger nailing to work. However, I assume it could solve the gross grain bending issue because you have wood grain running each direction in the different plys of the OSB board.
Does anybody have any other techniques they use for the wall anchorage in this scenario? Or do people use an entirely different framing technique in order to get these taller parapets to work without having to do kickers down to the roof structure? Redbuilt has the following technical bulletin which shows different framing techniques: Link
