how to build a reverse gear event (car going backward) in Adams/Car? 1
Fariborz90808888
Automotive
Apr 28, 2021
36
hi everyone
i'm trying to build a reverse gear event such as fishhook with the vehicle going backward or J-turn with the vehicle going backbard (in reverse)...
would you please help?
thanks a lot by the way because of many helps i have received in this site
So what happens if you switch off the minimum speed sensor, and put in a negative speed for an event? Your speed sensitive steering boost may break.
Cheers
Greg Locock
[smile] thanks a lot Greg Locock
that's what i did... also a reverse gear was in order...
but would i also succeed in doing this with positive (1 to 5) gear and not a reverse (-1) gear?
would this be possible?
