How to calculate bolt load from AMSE BPVC. VIII. 1 6
shegzyplanet
6
Can someone help with an example of how to calculate required bolt load using AMSE BPVC. VIII. 1
I have tried it but it seem confusing
Refer MANDATORY APPENDIX 2 of ASME SEC VIII DIV 1
Are you referring to the bolt load used for calculations, or the one that you will use in actual operation?
i have a 1" ASTM 193 B8M Bolt to be used on a 26" vessel nozzle using spiral wound gasket. i want to calculate the correct torque value. if i have the correct bolt load, i can use T=KFD to get the right torque value... i want to calculate the required bolt load
I still need help to calculate the required torque value of the following
Bolt size: 2"
Bolt material: A193 B8 Class 2
Can someone help with the steps from beginning to the end?
have u calculated bolt load ?
if yes, use formula of torque.
T = KFD
K = 0.2 F IS LOAD PER BOLT D is minor dia.
My main problem is calculating the bolt load. Can you please put me through on calculating the required bolt load?
Please can someone assist with how to calculate either bolt stress required or bolt load
Bolt size: 2"
Asked and answered. See ASME PCC-1, Appendix O. Beyond that, you need to get your employer to assist you with that. We don't do free hand-holding on eng-tips.com.
This isn't a comprehensive how-to instructions forum.
It is for giving a receiving tips to help you get past a tricky problem.
What is the definition of "F" in the cited provision? I know F is a load to calculate torque here, then what end result is expected from stretching the bolt - close gap, pre-load the bolt, or produce clamping force for shear? Sorry, I am not a ME, nor familiar with AMSE (ASME?) provisions, so the question could sound stupid.
Gentlemen.
Kindly help confirm if this is correct.
Stress = Force/Area
[highlight #FCE94F]Force = Stress X Area[/highlight]
Stress = Bolt Yield = 105000 Psi (For A320 L7 from ASME B31.3)
Force = Bolt Load = ?
Area = Tensile Stress Area = 0.6057 sq.in (For 1” bolt from ASME PCC-1)
Force (Bolt Load) = 105000 X 0.6057
= 63598.5 lb
Kindly confirm if this can be used to calculate bolt load before using [highlight #FCE94F]T=KFD[/highlight] to calculate the torque value
Why would you use a bolt stress of yield? Have you gone through ASME PCC-1, Appendix O?
F can be any magnitude, but only one is meaningful for your application. What is your application - close gap, pre-tension....?
