The pipelines I am working on are refrigeration pipe with rigid PU foam insulation. At the location of support we use prefabricated high density ring block (cut into two pieces) between pipe clamp and the pipe, and in other place the insulation is with lower density and injected on site. The compressive strength & modulus of PU foam are obviously much lower than steel, therefore using rigid support in pipe stress analysis is kind of conservative, which yield very high thermal stress. Therefore it is better to enter the stiffness of the support. The tension/compression stiffness formula is E.A/L, can I calculate the stiffness of pre-insulated support in the same way? eg.
Stiffness = E*(D*W1)/L
where E is the compressive modulus of insulation material (~10Mpa)
D is the outside diameter of pipe
W1 is the width of prefabricated ring block (or should I take the width of pipe clamp, which is smaller than the ring block width?)
L is the insulation thickness of insulation
