nikolastrojman
Industrial
- Jul 17, 2007
- 68
Hello everyone,
I’m seeking your opinion on managing support lift-off scenarios, particularly in systems where there’s a significant difference between "normal" operating temperature (e.g. 60°C) and design temperature (250°C).
Here’s the situation which I encounter many times when doing stress analysis:
- At ambient (installation) temperature, the rigid support carries the pipe's weight as expected
- At normal service temperature, the stress analysis software shows vertical displacements in the range of 0.5 mm to 2 mm
- for design temperature, the lift-off becomes more pronounced
Should we consider only the design temperature scenario and use variable pipe supports/hangers, which are very expensive and are treated as specialty support items to be used only when required -> looking from practical/economical point of view.
Let's assume hot-sustained has already been checked and stress are in compliance with the code (the system is also ok without the supports which are lifting).
We are talking here only about whether to leave the rigid support in place, remove it (which increases line sagging then) or switch to variable supports.
Which are the strategies you use to avoid overengineering the system from support concept point of view.
