mechengineer
- Apr 19, 2001
- 261
Hi Everyone,
How to calculate the thickness of spherical crown head with a stiffener under external pressure at convex side for a heat exchanger with a floating head?
The spherical crown thickness of floating head under external pressure (shell side), 53.2 kg/cm^2 at 399 deg.C. Shell ID=1100 mm and Radius of spherical crown=900 mm. The required thickness is about 72 mm (SA-516Gr.70) without stiffener by code calculation. I would like to add a stiffener (like a partition plate) to against the external pressure, whatever the thickness controlled by buckling or strength, however ASME Code has no a formula for such case. I would appreciate if any one shares the experience on such issue and provide a method/formula if possible. Thank you.
