Harriss1972
Can anyone recommend a design guide or go-by for determining the weld or stitch weld needed to attach a single bottom cover plate to a wide flange beam? I've found just a little bit in Omar Blodgett's "Design of Welded Structures", but not much more.
Additionally, I have a problem with a round cantilevered oil well casing that is going to be excavated to a depth of 15 feet. Thus, the project will be leaving a 10,000 pound wellhead supported like a flagpole on a 20" diameter casing. That casing will have "windows" cut out of it in order to access and wrap an inner casing with a corrosion arresting material. My role is to design a rehabilitation solution so that the built up section of a 20" diameter round casing with "windows" and the new steel welded to it will have equal strength to the uncut 20" casing.
I've already chosen beam sizes to weld to the exterior of the casing that will provide equal or greater axial and bending capacities of the uncut 20" well casing. I'm at the same quandary as in the first question in paragraph 1: How do I design the weld or stitch weld to attach the new steel to the round pipe casing? I need the added moment capacity and shear capacity down in the excavated hole 15 feet from the surface for when the wind load blows on the wellhead. How do I calculate the weld strength and weld needed between the existing 20" diameter pipe and the wide flange beams that I will attach to it?
thanks for any help/recommendations/suggested design guides for these two similar questions.
