How to cancel the message window in non-linear analysis
ThomasH
1,190
Hi all,
I have a problem that irritates me. One reason is that I think I have solved it before but can't remember how.
I am running a series of non-linear analysis's. Some complete and others don't due to convergence issues. That is ok because I am searching for a limit in the structure.
But I am running using the "Analysis Set Manager" in Femap and when an analysis does not complete there is a message window appearing with diagnostic info. I have to click a button for the next analysis to start.
Is there a way that I can make all the analysis's just run without the message?
Help would be appreciated.
Thomas
Run analysis with .bat file and then load results into Femap.
That is an option. But I would like to have the Analysis Manager active for handling the parametric study.
Thomas
