How to Change Graphic Window Background?
moleary
Computer
Mar 23, 2005
38
Does anyone know how to change the background color of the graphics window? By default it is a blue to white gradient. Is there an API call for this also? Thanks for any help!
Thanks for the help! Anyone know of an API call for this?
To toggle between gradient colour on or off the API Call is
swColorsGradientPartBackground
For Viewport Background the API Call is
swSystemColorsViewportBackground
For Top Gradient Color it is:
swSystemColorsTopGradientColor
For bottom color:
swSystemColorsBottomGradientColor
Hope this helps
regards
vik
Here's a very simple macro I use to change (toggle) the backgound color (non-gradient) quickly when I save new library features, etc. I hate how the colored backgound appears when I use the design library but also despise working with a white background.
' Viewport Background Toggle.swb
Dim swApp As Object
Dim swDoc As Object
Dim nCurrentColor As Long
Sub main()
Set swApp = Application.SldWorks
Set swDoc = swApp.ActiveDoc
nCurrentColor = swApp.GetUserPreferenceIntegerValue(swSystemColorsViewportBackground)
'swApp.SendMsgToUser (nCurrentColor)
If nCurrentColor = 16777215 Then
swApp.SetUserPreferenceIntegerValue swSystemColorsViewportBackground, 14155261
Else
swApp.SetUserPreferenceIntegerValue swSystemColorsViewportBackground, 16777215
End If
swDoc.GraphicsRedraw2
End Sub
A simple modification can be made to the above in order to use the gradient feature.
Remember...
[navy]"If you don't use your head,[/navy] [idea]
[navy]your going to have to use your feet."[/navy]
