how to change the number of engine mounts and change their attachment in an engine model in Adams? 1
bj7777
Automotive
Feb 1, 2019
33
hi
i saw a parameter variable once when i was perusing through an engine model and i saw a parameter with which you could determine the number of engine mounts in an engine model... i'm not sure if it was a parameter variable or something like that...
i was wondering if i could change the number of engine mounts with a parameter variable or something like that...
if that is not possible, is it possible to change it with the engine construction frame ?
thank you very much...
