ayelamayem77
- Oct 2, 2012
- 47
Dear all
according to CSI recommendations to calculate local p-delta effect
(which is associated with local deformation relative to the chord between member ends)
we have to consider one of these methods:
1-Apply design factors, which ETABS post-processing assumes to be done. These factors are therefore included in design, when applicable.
2-Divide members into segments (at least two per column), then run each load case separately with a different P-Delta load combination for each.
my question is what are these design factors according to ACI-318-08 CODE??
and how to apply them in etabs??
thanks in advance.
thanks in advance.
