Mechv5
- Jan 28, 2009
- 30
I have to design a bowden-cable between 2 parts in an assy and I need to create the path curve as a 3D curve, in the context of the assy. To do this, I need to reference on some geometrical elements (edges, points, etc.) from other parts in assy, but I cannot/don't know how to use geometry from other parts in my new created part (where I will make the cable). It would be great if I could use the "Include" command, but I cannot access it (or I don't know where to find it) when I'm not in a sketch environment (I need to import the reference geometry in the 3D space, not in sketch). What should I do to be able to make the cable?
Thank you in advance for your answers!
