Theophilus
Does anyone know of a way to create a logarithmic spiral? I need to generate a surface for a part to follow in an animation, and this appears to be the shape I need.
I have a hinge sort of detail. In normal SolidWorks I can accomplish what I need with a gear mate, but Animator doesn't do anything with the gear mate and lets everything flop around as if the mate didn't even exist (figures).
So here's the situation. I have two main parts (like doors), connected with an intermediate hinge piece. The intermediate piece supplies the axles for the doors. The doors rotate from folded atop one another to parallel with one another (180* of motion). However, the hinge piece rotates only 90* in this same course.
So the door rotates 180* about the other door, while the hinge piece rotates only 90*. I'd like to extrude a surface--which is starting to resemble a spiral of some sort--that I can use to control the rotation of my door when I rotate the hinge piece only 90* such that the door rotates 180* exactly. (This is quite a complicated hack for an Animator limitation--anyone know of anything simpler?)
So--is this what I'm looking for? If so, with the ratio of angle change of the door to the hinge piece being 2:1, what would the formula look like (remember, I'm an industrial designer, not an engineer--I didn't have that class [well, I probably did, but ditched the engineering career for ID at that point]). I found this, but don't know how to turn this into something useful within SolidWorks:
Jeff Mowry
Reason trumps all. And awe transcends reason.
Jeff Mowry
