How to create a point at the intersection of two lines?
JSMachine
31
Forgive me for such an elementary question, but I can't figure out how to do something.
I have a circle drawn in sketch. I have drawn a line from the center to the outside, straight up. The cursor automatically snaps to the 90 degree point, and I can put a point there or draw another arc at that specific point with ease.
However, when I draw a line off to the side, let's say 87 degrees, and then try to create a point at the intersection of that line and the circle, it won't. All it wants to identify as a possible place for a point is the 90 degree spot.
How do I make it create a point at the intersection of this line and the circle?
Create a point on the line, or circle, near the intersection of the two. Ctrl+select the point and whichever entity you didn't create the point on and create a coincident relation.
Jeff Mirisola, CSWE
My Blog
FWIW I prefer a pair of coincident relations over an intersection relation. Coincident can be repaired, intersection can not.
Ok, thanks. I got the point put where I want it. I am wondering though, is it simply a graphics thing how when I zoom up, the point no longer seems to be on the intersection but on one of the two lines?
Yes, it's a graphics thing. I just drew a circle and created a line with a coincidental point on it, and if I zoom in far enough it shows the line extended outside of the circle.
E. Morel
M.E.
Ok, good deal. Thank you all for the help. This forum is saving grace.
