How to create an "add-in"
Ralph2
Industrial
May 3, 2002
345
Can someone tell me how to add GearTec 2013 from Camnetics to Solidworks 2014 as an "Add in".. is it possible?
Thank you for your time.
With GearTec installed I would expect it to show up in SWX. However, you should be able to go into SWX Tools -> Add-ins (at the very bottom of the Tools menu. It should show up there and then you would just check the appropriate box for it. If it does not show up there then I suggest you contact GearTec support for their help.
- - -Updraft
Thanks.. but it does not show in SW as being available.. and the CAD tab is greyed out in GearTeq. I have a help request in to Camnetics..
Thanks all.
Problem resolved.
