how to define a request for specifying the wheel angle in MSC Adams/car?
Fariborz90808888
Automotive
Apr 28, 2021
36
hi
i intend to find out the wheel angle of the vehicle model in Adams/Car while steering in a subsystem assembly and a full vehilcle assembly, by defining a request...
how can i do that ? what parameters do i need for defining that request? what is the best way to do that?
appreciate your help.
hi Greg Locock
thanks for replying
No particular wheel angles needed... i just need front wheel angles ... i could not find it in all the result sets, requests and objects...
the tuv_front/tuv_rear request gives the toe angle but it shows peculiar results in some tests and i can't consider it as the wheel angle... i don't know if i have chosen the right toe angle request that signifies for the wheel angle...
for instance the tuv_front gives the following result in a step steer test:
that's why i'm trying to define a request that gives the wheel front angle with respect to the chassis longitudinal axis...(usual wheel angle)
appreciate your help as always
do you mean the vehicle longitudinal velocity?
nearly correct ... that is actually 22.22 m/s...
I think you are just measuring wheel rotation as it rolls down the road. Look in the adm for the request, find what marker it is using. animate that.
Cheers
Greg Locock
thanks a lot Greg Locock
but would you please elaborate on that... how can i do that? how can i find that marker? do you mean i should modify the request tuv_front/rear?
Look in the adm file. text search for the request
You'll find this
REQUEST/3032
, TITLE = tuv_front
, COMMENT = front suspension TUV toe and camber
, CUNITS = "no_units", "no_units", "no_units", "no_units", "no_units"
, CNAMES = "", "Average_Camber", "Left_Camber", "Right_Camber", ""
, "Average_Toe", "Left_Toe", "Right_Toe"
, RESULTS_NAME = tuv_front
, FUNCTION = USER(1122, 979, 998, 616, 0)
so markers of interest are bolded . Those are the inputs to resqub 1122. animate those markers, read the help on the reqsub, see if you can figure out what is wrong.
Cheers
Greg Locock
sure i will do that...thnak you for elaborating... i will keep you apprised...
