How to define an Array?
feajob
Aerospace
Aug 19, 2003
161
I would like to know how can I define an Array in VB (Excel)?
I tried the following commands:
Dim myArray(5) As Integer
myArray = Array(12,3,13,64,245,75)
But, I got a compile error as follows:
Can't assign to array
Please let me know what is the proper way for defining an Array?
Thanks,
A.A.Y.
The two statements don't work together.
You can either use:
Code:
myArray = Array(12, 3, 13, 64, 245, 75)
' (no dim statement)
' won't work if option explicit is included
Or else you can use:
Code:
dim myArray(5) As Integer
myArray(0) = 12
myArray(1) = 3
myArray(2) = 13
myArray(3) = 64
myArray(4) = 245
myArray(5) = 75
Or dimension the array as a variant (which is the default if you don't dimension it). Then you can leave the Option Explicit statement in place.
You can also transfer the contents of a worksheet range to an array:
Code:
Dim MyArray as Variant
MyArray = Range("MyRange").Value2
Note that:
1. The array is automatically re-sized to the size of the range, so you don't need to specify the array size (in fact it won't work if you do).
2. Use .Value2 rather than .Value (the default) or nothing because it is quicker and it won't truncate values formatted as currency to 4 decimal places.
3. All arrays will be 2D, base 1, so a range of 1 row x 10 columns will come in as MyArray(1 to 1, 1 to 10).
Doug Jenkins
Interactive Design Services
No, that doesn't work for me. The following code gives an error ("Compile Error: Can't Assign to Array"):
Code:
Dim myArray(5) As Variant
Pete - you didn't read my notes!
Either
Dim MyArray as variant
or
Dim MyArray() as variant
will work.
The array is automatically redimmed when you assign something to it.
Doug Jenkins
Thank you for your replies. They helped me to solve my bug.
A.A.Y.
