ajroc
Aerospace
- Jul 14, 2006
- 14
I have a quick question. I have a I beam whose cross section which is built up using rectangular members. The section has a moment applied to it. When I do an analysis of the section using FEA, it is obvious that a portion of the applied moment is reacted by bending in the web, and the rest by axial loads in the top and bottom caps. I can determine what portion of the applied moment is reacted by the webs and caps by comparing EI's, however I do not have a good explanation as to why the web bends and the caps are in extension other than intuition.
As I have many sections to size, I do not want to build FEA models for all, but would like to create a tool to do so quickly by hand.
Looking at a rectangular member located at the section CG , I know the area moment of inertia is 1/2 bh^3. If that member moves away from the section CG (say the upper cap), I= 1/12*b*h^3+b*h*d^2.
If I take the ratio of the two I's (with the member away from the section CG in the numerator) the result is 1+12d^2/h^2. the term 12d^2+h^2 is the additional moment of inertia (and thus additional stiffness) that member has because it is away from the section CG.
Using this second term in the ratio (12d^2/h^2), I can predict for any member in my I beam (say the cap), how much bending will occur and how much of the applied moment will be reacted out using a axial load times moment arm to section CG.
I am struggling with how rigorous this is - does this method make sense? Am I overlooking something? I have attached a simple example to help explain my method.
thanks in advance for your help
