how to determine if DC mtr is PM
paulmars
131
Im told I can test using my dvm, but how?
Tks, >p
If you turn the rotor and measure a "substantial" voltage, then it is PM.
Substantial means that the voltage shall be close to nominal when running rated speed. And, say, 10 percent of nominal when running one tenth rated speed.
A motor with separate (or serial) excitation shows a lot less voltage.
It is, of course, also a good idea to look at the connections. If there are connections for an external field, it sure has one.
Gunnar Englund
100 % recycled posting: Electrons, ideas, finger-tips have been used over and over again...
Another way is to turn the motor by hand, and then short it. If it is much harder to turn, it is a PM. Works for both brushed and brushless.
