Sorry about my signiture. Missed the ending. But you need to start looking through your records for each part looking for defects. Looking for the cycles made before defects start appearing. Set your PM cycles for 10% less then then amount.
A typical PM consists of the following:
1: Open mold and visible check for anty physical damage to cavities,parting lines or shut-off area.
2: Conduct check for flashed plastic in cavities, screw holes, interlocks, ejector system, etc.
3: Inspect parting line vents for residue and any evidance indicating improper operation.
4: Check for loose or disconnected electrical wiring.
5: Check for missing or damaged external mold components, insultation plates, water and electrical plaques, ejector housing guards, etc.
6: Begin disassembly and evaluate general mold conditions. Inspect ejector system, springs, bushings, leader pins, slides, etc.
7: Inpect water lines, water channels, baffles and bubblers for scale build-up or corrosion. (Boil out as needed)
8: Record all findings on "Mold Evaluation Report"
Robert Anderson
