Hi Guys,
I have designed a system using a 10 mm mild steel flat bar and 5 mm flat bar assuming that 10 mm mild steel flat bar (40 x 600 mm )would withstand the load of 3 tonne.
Can any one please let me know the procedure to calculate the thickness of a plate to withstand 3 tonne load (based on australian standards)? Also, how much load can 40 mm diameter pin withstand?
