How to format the texts belonging to the titleblock
JeniaL
547
i'm trying to force a macro to set up desired font for a titleblock but seems like it doesn't work.
here's the code (changing font setting doesn't work in this macro)
Sub CATFormatTBText(textName As String, anchorPosition As String, fontSize)
'How to format the texts belonging to the titleblock
Text.Name = textName
Text.SetFontName 0, 0, "Century Gothic (TrueType)"
call Text.SetFontName ( 0, 0, "Century Gothic (TrueType)")
Text.AnchorPosition = anchorPosition
Text.SetFontSize 0, 0, fontSize '* A4TextFmt
End Sub
this works with another macros but with attached macro this code doesn't work.
what's the problem? two different titleblocks created from the same master macro but in one case i can control font settings through the
macro in other case i cant.
 http://files.engineering.com/getfile.aspx?folder=aaee1f19-b8a5-48a2-a877-5f86d2fbaebb&file=A4_FRAME.zip
already replaced but i want to force output desired font for a titleblock thru the macro. as for now no matter what font defined
in macro when i run titleblock it takes font setting from standard.
