Hi and good morning to all, I have a problem regarding the hysteresis graph where I get either linear or not proper results of hysteresis. I already try to adjust the material property, load and step but non-work. May anyone help me check where actually I was wrong and I can adjust? Here I attached the reference paper and the abaqus cae (where currently i edit at C SOLID BASE-edit dr-Copy. Thank you so much
