How to request sectional forces for shell elements in ABAQUS
Gov45
Automotive
May 8, 2024
14
Hello all
I would want to write the sectional forces in 2D shell elements of a specific section in my model.
How do I request the same in ABAQUS.
*SURFACE, NAME=sectional_forces_nodes, TYPE=NODE
sectional_forces_nodes, 1.
*SECTION PRINT, NAME= section_SF, SURFACE= sectional_forces_nodes
AXES=LOCAL
SOF
SOM
I used the above keyword, but got the following error
***ERROR: THE SECTION SURFACE SECTIONAL_FORCES_NODES CONSISTS OF A NODE-BASED
SURFACE; THIS IS NOT ALLOWED.
As I wanted to create a surface in *SRECTION PRINT, I created a node based surface
For shells, you can request the section forces directly. For example:
Code:
*ELEMENT OUTPUT
SF
