HOW TO GET POSITION AND ROTATION VALUES
suleymanyaman
Industrial
Jul 30, 2013
29
Hi, I want to get position values and rotation values which belongs interfaces by creating macro?CAn you give me any idea?Thank you.
I glanced at this link but in here if I am not wrong,user enter into some values and user sets or changes rotation values.How ever I would like to get values automaticly.I add an image file.And also I want to get this values.I am appraciate for helping.
 http://files.engineering.com/getfile.aspx?folder=b0f49561-a6f7-4b1f-a7f8-18b9b534f190&file=translate_rotate.bmp
Do you want to measure distance and angle between two objects ?
Actually,I want to measure an interface coordinates or position values(X,Y,Z,ROTX,RotY,RotZ) from world zero.
For example, I found my part's volume and mass thanks to below codes.And also ı want to figure out position (x,y,z,rotx,roty,rotz) by like these codes.Is it possible?Thanks a lot now.
MsgBox "Part Volume: " &MyProduct.Analyze.Volume
MsgBox "Part Mass: " &MyProduct.Analyze.Mass
Option Explicit
Dim strSearch As String
Dim PartFound As Boolean
'Dim MySelection As Selection
Sub CATMain()
Dim MyDoc As Document
Dim MyProduct As Product
Set MyDoc = CATIA.ActiveDocument
Set MyProduct = MyDoc.Product
'Set MySelection = MyDoc.Selection
strSearch = InputBox("Input Search String")
PartFound = False
If strSearch = "" Then
MsgBox "Search String is Empty", vbExclamation, "Error"
End
End If
Call Traverse(MyProduct)
If PartFound = True Then
MsgBox "Part Found", vbInformation, "Success"
Else
MsgBox "Part Not Found", vbExclamation, "Fail"
End If
End Sub
Sub Traverse(MyProduct As Product)
Dim i As Integer
Dim PartName As String
Exit Sub
End If
For i = 1 To MyProduct.Products.Count
If MyProduct.Products.Item(i).Products.Count = 0 Then
PartName = MyProduct.Products.Item(i).ReferenceProduct.Parent.Name
If PartName = strSearch Then
PartFound = True
Set MySelection = MyProduct.Parent.Selection
MySelection.Clear
MySelection.Add MyProduct.Products.Item(i)
CATIA.StartCommand "center graph"
CATIA.StartCommand "reframe on"
End If
Else
Call Traverse(MyProduct.Products.Item(i).ReferenceProduct)
End If
Next
End Sub
Actually I am not able to find the solution to your problem either manually or through macro. I am searching for the same. If I find it I'll let you know. May be someone else will do it for you
Thank you Iam just want to be clear.By this way I shared this explanation.I am glad to help :)
First advice, check Eric's post about posting pictures, if you are on a mobile connection you don't want to do traffic downloading a bmp file with big size, so you will not get an answer so soon.
Second advice is to check the v5automation.chm file in CATIA installation folder, there is an example there how to copy-paste-keep-absolute-position of a product, you can use it to understand more things.
Fernando
Firts of all thank you a lot dear ferdo.I cared your advices appreciately. Altough I have subscirption his blog, the blog still ask me password and I did not receive any password from.Just an email is sent and it said "EMAIL Subscription Confirmed" but I dont still access.
Secondly I tried to entegrate copy-paste code unfortunately I am unsuccesful about this.I add text file.This file returns "set component is not supported in Visual basic" compile error.How can I figure out?
 http://files.engineering.com/getfile.aspx?folder=5a8b0bc2-c3a1-4454-943a-52d1e354accd&file=position_calculation.txt
Actually it is confusing.briefly ı try to explain again sorry about amateur student mavement:( I add new one.I understood calculation matrix and inverse but how can I have myInputPart's X,Y,Z values?I mean my target is which I want to have position values I want to access,so I did not entegrate and call in CATMain.If I didnot tell I can try can and give more detail.
 http://files.engineering.com/getfile.aspx?folder=4e3dbb40-a0ba-4505-ad93-7cc23a19f449&file=position_calculation_(1).txt
This is what you are looking for:
Code:
Dim oAxisComponentsArray(11)
[i]prod[/i][highlight #FCE94F].Position.GetComponents[/highlight] oAxisComponentsArray
Check the online doc to understand the oAxisComponentsArray(11) values...
Eric N.
Thank you itsmyjob.I checked v5automation.chm before and until the now I understood that RotX,RotY,RotZ values(it means you know for example:45degrees,0 degrees,90 degrees etc.)I cannot reach by this method.Can you give me any idea for this problem?
Well, you will have to do some math as this is what CATIA gives you.
Eric N.
It is OK itsmyjobs I will struggle about this.I am glad your support.I hope overcome that.
REGARDS
