How to hide a list
I don't think that's possible when using Validation..
You can put the data on another sheet (see the second example I sent). You have to type the area because the data validation will not let you choose another sheet.
The trick is give a name to the range in the other sheet.
For example attached in sheet2 I highlighted A1:A8 and typed insert/name/create/TopRow.
Then in sheet 1 data validation tab in list box I put =TempData.
Then as stated sheet 2 could be hidden if desired.
 http://files.engineering.com/getfile.aspx?folder=ef65a6f1-f062-4eca-aa95-8443c0443fc3&file=exBook1.xls
That worked really well guys, thank you very much.
Nice way to start off the week :)
Using names is a great tip. In this case you want a "Workbook level" name. This is what EXCEL does by default. But remember that you can creat "Worksheet Level" names. See link below.[smile]
mhtml:
[link ]
btn_liprofile_blue_80x15.gif" width="80" height="15" border="0" alt="View Clyde's profile on LinkedIn
[/url]
