We are in the process of performing fatigue studies on branch connection (like a weld-o-let) that contain relief valves under a "Chatter" scenario in order to predict future failure. The question is: How do you measure, and record, the resulting forces at the branch during a chattering event so that the proper fatigue analysis can be performed?
We thought of placing accelerometers around the branch connection, but didn't know how to convert those readings into resulting forces. We are expecting the forces to be the result of the pressure wave back from the valve due to the sudden closure and the forces from the relief valve Disk closing against the nozzle due to the spring.
Or if the branch was completely restrained, would load cells work?
Many Thanks,
Many Thanks,
