psustudent
Hello!
I am trying to output the displacement values at about 1000 nodes in a straight line across the top of a rectangle. However, due to the node labeling convention the nodes get put out of order (in other words they are no longer ordered based on their x-coordinate) when I output them to a .rpt file. Is there anyway I can change this so that they are outputted in order based on their x-coordinate? The nodes are part of a set I created.
Thanks!
Thanks!
