how to perform nodal analysis in adams car??? 1
bj7777
Automotive
Feb 1, 2019
33
hi
i'm trying to perform nodal analysis and also stress and strain analysis on flexible bodies in adams/car...
i don't know how...
would someone please help??
thanks a lot
I think you mean modal analysis. That is most easily available in ADAMS/Vibration. I doubt you can do stress and strain analysis because the flexible part is represented by an MNF file. I could be wrong, I have done neither. The usual process which is what I used to do is to write the forces out from ADAMS, as time histories, and then apply them to the FEA model in a proper FEA program.
Cheers
Greg Locock
hi GregLocock
Thanks for responding
Actually i meant nodal analysis. Because i need to calculate one specific node's displacement, acceleration and ...
i also need to know how can i find specific nodes in Adams/Car itself (if possible) without using other FEA or CAE softwares...
thanks a lot
Oh, OK. For displacement you'll need something like
REQ/81102103,DIS,I=1102103, J=1183103, RM=1183103
,C=LF Displacement of P3 LCA Bushing from Subframe wrt Bush Coord
and for acceleration
REQ/47400, I=47400,J=3,RM=3, ACC,
,C = Engine Cg Acceleration
Look up REQUEST in the basic package -> Solver help.
Cheers
Greg Locock
Hi Greg Locock
Thanks a lot
but i haven't worked with solver at all... is the REQUEST available in Adams/Car Help???
How can i find the solver help in Adams?
Help->ADAMS Help takes you to browser (don't use chrome, I use IE) allow blocked content,->adams basic package-> adams solver
Cheers
Greg Locock
Thank you very much for taking your time
