JimboJones21
- Mar 21, 2005
- 55
Hello All,
I wanted to know if there is a way to protect RS485 IC (75176) from high voltage such as 50V because if I get a spike on my lines my 75176 chip blows.
Can you simply hang a 15Volt zener on each line to ground to sink the 50V or put a fuse in line with the lines? It has to be PCB mountable also.
Thanks for the help!
