singletreelane
- Dec 21, 2014
- 1
I came across this thread thread286-145004
I felt the answers given were either completely wrong or not helpful. I am a Swiss CNC Machinist currently going to school for nanotechnology engineering. Anyhow I feel as tho I can answer this question a little more clearly.
Question
Well I know how to read a micrometer very well, my question is on how to say the readings you get.
You learn at an early age the following (this part makes sense to me, both how you say it and its mathematical representation):
10 = tens place
1 = ones place
.1 = tenths place = 1/10
.01 = hundredths place = 1/100
.001 = thousandths place = 1/1,000
.0001 = ten-thousandths place = 1/10,000
.00001 = hundred-thousandths place = 1/100,000
.000001 = millionths place = 1/1,000,000
BUT, i am confused about how i hear people "saying" micrometer readings, they dont seem to reflect the above (1" micrometer)
.1 = hundred-thousandths of an inch ?
.01 = ten-thousandths of an inch?
.001 = one-thousandths of an inch?
.0001 = tenths of an inch? also heard ten-thousandths??
.00001 = ten-millionths of an inch?
.000001 = millionths of an inch -or- microinch?
some of these i may have listed incorrectly, thats what i need help with.
My answer
In a machine shop increments are based on the .001 (thousandths place)
Look at it this way if .001 = 1 thousandth or 1 thou then .01 is 10 thou .1 = 100 thou .0001 is a tenth of a thou so it's called a tenth .00001 i guess should be called a hundredth but it's not this called 10 mill. .00001 is not even really used in machine shops anyhow. Most mills and lathes only allow to offsets of .0001 and a Swiss will allow up to .00001 but every swiss guy I know including myself only uses increments of.00005
i hope this helps.
Question
10 = tens place
1 = ones place
My answer
i hope this helps.
