How to removw y UserRefProperties ?
eperichon
Aerospace
Jan 16, 2013
7
I have this following code that i try to modify. In fact I want to create a custom property named "AU_COMPO" = 2 in each components of my tree. The code works but the problem is that it adds as new string as the number of component : "AU_COMPO" , "AU_COMPO.1" , "AU_COMPO.2" "AU_COMPO.3" ....
I just want to check if the custom properties already exists, and if yes, to go to the next component witouht any creation. How can I do that ?
Here is the code :
Code:
Sub CATMain()
    GetNextNode CATIA.ActiveDocument.Product
End Sub
Sub GetNextNode(oCurrentProduct As Product)
    Dim oCurrentTreeNode As Product
    Dim i As Integer
    [COLOR=#4E9A06]' Loop through every tree node for the current product[/color]
    For i = 1 To oCurrentProduct.Products.Count
        Set oCurrentTreeNode = oCurrentProduct.Products.Item(i)
        Set oparameters = oCurrentTreeNode.ReferenceProduct.userrefproperties
        [COLOR=#4E9A06]' Determine if the current node is a part, product or component[/color]
        If IsPart(oCurrentTreeNode) = True Then
            [COLOR=#4E9A06]'MsgBox oCurrentTreeNode.PartNumber & " is a part"[/color]
        ElseIf IsProduct(oCurrentTreeNode) = True Then
            [COLOR=#4E9A06]'MsgBox oCurrentTreeNode.PartNumber & " is a product"[/color]
        Else
           [COLOR=#4E9A06]'MsgBox oCurrentTreeNode.PartNumber & " is a component"[/color]
            [COLOR=#4E9A06]'if oparameters.getitem("AU_COMPO")<> 0 then[/color]
            oparameters.CreateString "AU_COMPO", "2"
            [COLOR=#4E9A06]'End If[/color]
Thank you for your help
Edouard
        End If
        [COLOR=#4E9A06]' if sub-nodes exist below the current tree node, call the sub recursively[/color]
        If oCurrentTreeNode.Products.Count > 0 Then
            GetNextNode oCurrentTreeNode
        End If
   Next
End Sub
Function IsPart(objCurrentProduct As Product) As Boolean
    Dim oTestPart As PartDocument
    Set oTestPart = Nothing
    On Error Resume Next
        Set oTestPart = CATIA.Documents.Item(objCurrentProduct.PartNumber & ".CATPart")
        If Not oTestPart Is Nothing Then
            IsPart = True
        Else
            IsPart = False
        End If
End Function
Function IsProduct(objCurrentProduct As Product) As Boolean
    Dim oTestProduct As ProductDocument
    Set oTestProduct = Nothing
        Set oTestProduct = CATIA.Documents.Item(objCurrentProduct.PartNumber & ".CATProduct")
        If Not oTestProduct Is Nothing Then
            IsProduct = True
        Else
            IsProduct = False
        End If
End Function
Hi
With the code bellow you can remove them all in selection. Is easy to modify this code to achieve what you want
Code:
 Sub CATMain()
Dim oSel
Dim InputObjectType(0)
Dim Status
Set odoc = CATIA.ActiveDocument
Set oSel = odoc.Selection
InputObjectType(0) = "Product"
oSel.Clear
Status = oSel.SelectElement2(InputObjectType, "Select the product", False)
If (Status = "Cancel") Then
Set oSelectedProduct = Nothing
Else
Set oSelectedProduct = oSel.Item(1).Value
End If
Dim oParams As Parameters
Set oParams = oSelectedProduct.ReferenceProduct.UserRefProperties
For i = 1 To (oParams.Count)
    oParams.Remove (oParams.Count)
Next
End Sub
Fernando
thank you for the answer. I have resolve my problem with that code input inside my loop :
Code:
           While oparameters.Count > 0
           oparameters.Remove (1)
           Wend
