seepratik
- May 29, 2013
- 23
Hello Everybody,
I am runiing an fsi model for 40 seconds, but after some times running like 0.2 seconds for both solid and fluid, it hangs, and if I continue this way after 8-9 hours every window vanished showing that "your computer is low on memory".
Recently I have found that when before everything stops, (when the computer is already in hanged condition), the msg file of solid is increasing in size. Even when it stops working, I checked the msg file, I saw that, it completed running more than my expectation. So I think that, actually it works at that time, although it did not run upto the total time period. But after everything in stopped, I saw a notice in the taskbar that shows "would you want to restart or close your program" and i clicked on restart and it started running again. Is that called the restart analysis? If it is, then can I run the program after it shuts down form that point at which it stopped running? Can anybody tell me how to do that?
I have studied the manual but at some points I am not understanding. When newly tried to restart again, I went to the output tab in the main menu,in step modeule and found that there is an option of restart. When I clicked on that, it showed that the frequency is zero. How to change it, can you explain please?
For the recent days, after the program shuts down I don't see the close or restart option any more. The computer is not showing them anymore. Thats why I am not able to run it anymore from that stopped point.
Any reply would be of a great help.
thanks
Pratik
thanks
Pratik
