How to run an Abaqus (Python) code multiple times in a loop?
dfgsdfgfd
37
I'm trying to run my abaqus (python) code multiple times in a loop. I call it through the cmd window abaqus cae noGui=progname.py, which works fine. it executes my program that's in a for-loop for n in variable1: "PROGRAM CODE". At the beginning of my program I load the modules etc. and in the end I close the model and database with odb.close(), Mdb(). Generally, this works well. However, when one iteration/run fails (error message, e.g. due to convergence issues), the whole process stops and the console window closes. What I want is that the code then simply jumps to the next iteration of the for-loop.
Does anybody have a suggestion for this problem?
Thanks very much!
//Edit: When I run the code directly through the ABAQUS/CAE software, through "File/Run Script" it works well and jumps to the next iteration, but I want to run it through the cmd console.
Thanks very much for your answer. I tried to add try: "my Abaqus code" and except: pass/continue to the for-loop, but nothing changed. I suspect that the problem is related to Abaqus; maybe it closes down everything after an error, without even getting back to the original loop?
//edit: It actually seems to work when I don't "try:" the whole function, but only the part where I submit the job and wait for it to finish.
Abaqus does nothing special with the try. It work as in standalone Python.
