Fritzfrederix wrote: "At our plant we are using WinCC for visualisation, now for a new application I should need about 8 new licenses of WinCC which is very expensive. That why I thought off VB."
Fritzfrederix , it may be too late now but if you have a similar requirement again, it looks like our software OPCWare Client Developer (
is just what you need. You can use it in Visual Basic, and it works with any of the compliant OPC servers that are available for the Siemens S7-400 connected via an ethernet card (CP443-5) - if you need a list of the ones we recommend, please contact us via our website. In most cases, you would only need a single OPC server license and installation, typically these cost less than US$1,000, though some cost much less (as little as $120) and some are more expensive.
The OPCWare Client Developer installation includes two examples for storing data to a database - one of these uses a DSN connection, which is the normal method of connecting to remote databases such as SQL Server. Both examples log the item value, timestamp and quality to the database.
Now in addition to your data logging application, producing multiple HMI's with Visual Basic 6 is no problem using OPCWare Client Developer. The licensing options include Standard or Professional, both of which allow you to distribute your applications runtime free.
You could have your OPC server, 8 HMI's plus a data logging application all for less than $1,500, and with only limited programming required, keeping the costs down.
Best Regards,
Neil Kingston
Data Layers
