Put it in a drawing and then call that drawing file as your drawing template file.
Check the config.pro settings for drawing template location/definition.
I set a default. Is it possible to set multiple defaults? I can only see one file in the drop down menu when I go to create a new drawing and there are a couple that I'd like to be able to see
To expand on Ben's response - only one drawing template may be defined as the 'default' however any drawing files that are in the start_model_dir will be available as selectable templates in the bottom window. Multiple formats can be created and put into the pro_format_dir which will be available hitting the 'browse' button when using the 'empty with format' option. I have not found a way to populate the format drop down list box but this has never been an issue for me.
