I would like to specify the direction of surface roughness measurement.
Ex: Consider a rectangle: 100 X 50 X 10.
Roughness measurement length: 4 mm
I need 0.8 roughness along 100 and 1.6 along 50 (or) 0.4 for each diameter of 10 mm.
If the probe measures the roughness along 100 side, roughness shall be less than 0.8 for 4 mm.
If the probe measures the roughness along 50 side, roughness shall be less than 1.6 for 4 mm.
If the probe measures the roughness for dia 10, roughness shall be less than 0.4 for each circle..
Standard roughness representation allows to specify the direction of lay (cutting instrument direction). But I need direction of roughness.
Thank you
Sathish Rosario
Thank you
Sathish Rosario
