How to strengthen I beam deflection 1
Tnewbon57
6
Hi all,
I have a unique problem that I have been asked to solve and would appreciate some input from a more experienced group. I have been tasked with strengthening an existing structure made with two 6" X 6" square tubes as vertical posts supporting a 40' long (10 X 30) I beam horizontally, the tricky part is that this structure is holding up 8 heavy punching bags on trolleys. I need to strengthen the I beam without adding anything to the under side of the beam as it would inhibit the trolley. any thoughts would be greatly appropriated, thank you.
I can't do a mid span column, the bags are on trolleys so theye van be pushed to the side, and leave the floor open for mixed martial arts training. A Center post would interfere.
If the deflection issue is sideways, I would weld some rectangular tube to web of the beam as close to the trolley wheels as possible.
if lateral loads are the issue, then you need lateral loadpaths ...
how about adding a second beam parallel to the first, offset maybe 12", and weld/bolts plates top and bottom to make a torque tube ? then you need to take the lateral load down to the ground, something diagonal is suggested, maybe inclined verticals ?
of course, this assumes that the obvious solution (lateral bracing to a wall doesn't work.
Add two angles above top flange with vertical leg pointing down (similar to channel cap but with down hand welding only).
BA
