sateesh s
- Sep 14, 2017
- 1
[tt]thread554-177087
Hi i have a query regarding pro program, i am new to this as well, please help me out.
Simplified question is: how to suppress a part or parts in a assembly using pro program?
Question can be elaborated as my need:
Please can suggest how to create parameters, and how to write a pro program to suppress a part.
Please go through complete below example how am i expecting.
Example: Consider XXX.asm is my master assembly. XXX-A is sub-assembly & is having n number of parts, i need to write a program such that among n number of parts, only 3 sheetmetal parts should be controlled.(SHT1, SHT2, SHT3)
That is, if WIDTH of my master assembly is (WIDTH<=1000MM & WIDTH>=850MM), SHT1.PRT Should resume. SHT2 and SHT3 should get suppress.
If WIDTH of my master assembly is greater than 1000mm(WIDTH>=1001 & WIDTH<=1600), SHT2.PRT & SHT3.PRT should get resume and SHT1.PRT should get suppress. (i dont want to use pattern or family table as SHT1/2/3 are of different sizes)
can Width be defined in increment or decrement value of 25mm? how the program should be?
Below are the internal component id:
ADD PART SHT1
INTERNAL COMPONENT ID 48
END ADD
ADD PART SHT2
INTERNAL COMPONENT ID 49
END ADD
ADD PART SHT3
INTERNAL COMPONENT ID 52
END ADD
I TRIED THIS: (BUT GETTING ERROR)
IF WIDTH=1200
errorLogical expression expected.
ADD SUPPRESSED PART SHT2.PRT
errorExtra symbols found - ignored.
ENDIF
Heard can suppress feature but how to do for part,
THANK YOU
ADD PART SHT1
END ADD
ADD PART SHT2
END ADD
ADD PART SHT3
END ADD
IF WIDTH=1200
ENDIF
THANK YOU
