May 30, 2007 #1 badtrick Mechanical May 30, 2007 8 0 0 CH I want to turn a face of my solid around an axis? Wich command I need to use? I know its somewhere but I can't remember what or where it was.
Jun 1, 2007 #2 moldcore Mechanical Mar 19, 2004 82 0 0 US Not sure what you mean by face of a solid. Do you want to unstitch the face and rotate it, or rotate the solid about the face? In KeyCreator you can unstitch using the Modify>Unstitch command with option to Unhook, Copy, or Delete the face. To rotate use the Xform> Rotate command, either Move or Copy by designating one position or two position to establish an axis of rotation. Upvote 0 Downvote
Jun 3, 2007 Thread starter #3 badtrick Mechanical May 30, 2007 8 0 0 CH I found it! It's the command "Transform faces of a solid body" in "Modify". There you can turn faces around an axis or move them along a vector. Thanx Upvote 0 Downvote
