How would I form sheet metal using an assembly file for the shape?
michaelpc
Computer
Nov 11, 2015
20
I have a semi-complex assembly file that I would like to push into a thermoplastic sheet to make a loose mold. Is that something I can simulate in Solidworks?
Thanks much!
Import your assembly as a dumb solid and trace the shape, this will only work with single plane curves, compound curves do not work in Sheet metal.
B.E.
