Althalus
- Jan 21, 2003
- 152
I need help finding if this variable is specified anywhere.
I am looking at an HSS connection that isn't addressed in AISC DG 24. It is an HSS-to-HSS moment connection that is bolted via cheek plates.
Most of the connection calcs are no different than a standard bolted connection. But I've found one variable that isn't addressed anywhere.
Example HSS4x4x3/8
Question: Is the edge distance (for section J3.1) (lc in Eq J3-6c,d) only to the edge of the workable flat? Or somewhere in the radius? Or all the way out to the full 4" depth?
Example HSS4x4x3/8
Workable flat = 2-5/16"
3/4" bolt; 13/16" dia hole
For shear load in the depth of the beam (not the length of the beam) we only have 3/4" from the edge of the hole to the edge of the flat.
Where is that specified?
