I am at a loss to why I am finding such huge differences between allowable soil bearing capacities in the IBC vs NYC building code.
See the International Building Code table 1804.2 in the below PDF:
Table 1804.2 clearly shows gravels as 3000 PSF.
vs.
NYC building code (based off of the UBC):
Here Table 11-2 Note#4 shows gravels ranging from 12000 to 20000 PSF.
The NYC building code is about the same order of magnitude higher than IBC across the board for all soil/rock types. Footing sizes using IBC could be up to 7x as large!
Anyone know why, and which one should a shallow foundation be designed with?
vs.
