PagoMitch
- Sep 18, 2003
- 71
I originally posted this over in HVAC. but it was suggested that this might be a more applicapable forum.
Corrosion between Cu tubes and Al fins is accellorated in coastal areas. Military HVAC units (on buildings) are usually specified with Cu/Cu tubes/fins for that reason. While I can find a reference (sort of) to air salinity ( I cannot find a reference indicating how the values would be applicable to Al corrosion when mechanicaly bonded to a copper coil. Has anybody ever seen a study that measures the galvanic potential between Cu tubes and Al fins, at various distances from the shore? It would probably vary with temperature, and be influenced by wind and humidity, but it would be a useful criteria to use as a basis for justifying the expense of an all copper coil. This sounds like a great project for a Masters Thesis. I can make an educated(?) guess...say, 0 to 5 miles (or 10, or ?)from the coast is all copper in order to eliminate the problem. But it would be nice to find something a little more authoritative. This can't be the first time someone has posed this question...
