hydacad/ autoline problems
twd22285
Specifier/Regulator
Jul 31, 2007
73
I design overhead sprinkler systems and use hydracad 2008 and i am having problems with the autoline/autopipe command. The arrow that helps you pick a line/pipe to break is too small and to change the direction of the line is very touchy you have to be very exact. It used to be much easier the arrow was bigger and it was easier to change direction. i've tried every option and osnap setting it seems with no luck. any help would be much appreciated. thank you.
