Ok after spending some time doing some research I think I have it figured out. WHEN USING MRM FOR BASIN ROUTING, YOU MUST PROCEED WITH CAUTION. The problem is with the storm duration. The duration will be set a 2X the Tc. So if you have a 5 min Tc, the duration will only be 10 min. That duration may be fine when doing pipe flow analysis when you’re looking at the peak rate, however when routing the storm through a Basin, it’s not nearly long enough to provide enough runoff volume for proper basin sizing. If you use longer time of concentrations, you’ll find that although the peak flow rate is less, the runoff volume is greater and the required basin size will also be larger. For a few years now, I’ve noticed different Townships adopting Act 167 Plans that require the use of TR-55 to develop the Tc’s for use with MRM. Now I see that the reason. It’s because TR-55 will provide a longer Tc and runoff volume.
When I started this design, I was using the PaDOT average velocity charts to determine the time of concentration because it always provided me with the highest peak RATE but it also gave me a 5 min Tc. If I have a 0.81 Ac. watershed with C=0.40 and a 5 min Tc and a 100 year intensity of 8.19 in/hr… I have a tough time believing that only 0.27 inches of runoff will be generated from a 100 year storm event.
So the Moral of the story is when using HydraFLOW ….. NEVER EVER use the average velocity charts to determine the time of concentration for a basin routing. Using TR-55 isn't a bad idea but In my opinion it still generates runoff volumes that are too small when using MRM unless there's a way to change the storm duration.
HydroCAD, appears to be a better program because I can use whatever Tc I want and then manually adjust the duration so that that storm is generating the proper amount of runoff VOLUME. I have not finalized my research but it seems that storm durations around 30 minutes work well when using the average velocity charts.
BTW.... I have sized the facility using only 1/3 the perc rate measured with a double ring infiltrometer which excludes any lateral percolation. I'm using HydroCAD with a 5 min Tc and a 30 minute duration. The size of the system seems to be a little smaller than the total runoff volume that I originally calculated. When I route the storm it fills up top the top of the facility. I think I'm good.
Does anyone think I’m missing anything? I think this was a good discussion. Its nice to dust off the grey matter every once in a while.
