starspangled
Automotive
Hi folks,
I've just been in a spirited argument with several folks regarding hydraulic drum brakes and the relationships of master cylinder and wheel cylinder bore diameters and brakeline diameters.
It is my belief that changing to a larger or smaller master cylinder bore will have a direct effect on braking pedal pressure, and that a change in bore diameter of wheel cylinders will also have a direct effect, and that larger or smaller diameter brakelines can have a direct effect on the sensitivity or 'felt' pedal pressure in the system.
Their primary argument is that the brakeline diameter has absolutely no effect whatsoever, and that master cylinder to wheel cylinder bore relationships are not much of a consideration in a braking system.
The final consensus was that there may or may not be a difference due to master cylinder bore changes, and that there is virtually no effect in wheel cylinder bore changes, and no agreement was reached on brakeline diameter's effect on a braking system except that I was probably wrong.
So, I request some opinion and feedback from you engineers who have been involved in this area of the trade. Thanks for any assistance in this and also for any relevant formulae you may contribute.
Starspangled
Starspangled
