Hydraulic Hose Material
Minnyman
Marine/Ocean
Jul 28, 2012
11
Is there any way to create a material for a COTS hydraulic hose? Specifically I am trying to get the weight. All the manufacturer gives is the pounds per foot of hose. Do I have to convert that to density or something to create the material, or does Solidworks have a way to input this? My company doesn't have the routing add-in so I am not sure if it comes with that ability or not.
Thanks for your help.
Minnyman
I think I have it.
I know the ID and OD of the hose so can get the volume in one foot and since I know the weight per foot does that give me the density?
You can create a custom material with the required density then use that as the material selection for your hose. This would not require the routing module.
Hardie "Crashj" Johnson
SW 2011 SP 4.0
HP Pavillion Elite HPE
W7 Pro, Nvidia Quaddro FX580
