Hydraulic motor sizing
ahmadsalah
14
Hello Everyone:
I am designing a winch that would have a pull force of 20,000 lb. I determined that the torque required for it to move is 80,000 lb.in (I multiplied the force by the radius of the drum basically). I have selected a planetary drive that would give me a reduction of approximately 31:1 and now I am trying to select a hydraulic motor that would give me the required torque. I determined that I need torque of approximately 2500 lb.in but I fail to be able to select a suitable motor. would someone please help me?
Torque equals psi times cu.in./rev displacement divided by 2π
Ted
2500 PSI. so I need approximately 6 in3/rev. what type of motor do you suggest?
A gear motor. Look at Eaton CharLynn gerotor/gerolor motors.
Ted
