I am looking to validate the force output of a custom actuator that has the capability to push and pull at a 37,000 lb linear force, 4 inch stroke. We are looking at practical ways to quickly test this dynamic force output before moving on to the next phase of the project. One idea is to use a standard hydraulic shop press. This would allow us to maintain 37,000 lbs of pressure on the end of the power screw driven actuator as it is moving up/down. We don't currently have an automatic shop press and I wanted to know if typical shop presses can do the following:
-set to a certain force/pressure (perhaps with a 3 way valve on the hydraulic pump output)
-can be back-driven
-provides constant pressure while moving
We are looking into adding a custom circuit on a standard hydraulic press but I'm not convinced that a product like this isn't already out there.
Let me know your thoughts.
Much appreciated!
-can be back-driven
Much appreciated!
